Hello guys,
1)I have built a 2.4 gen3 block for boost and after installing it started priming the oil pump. To my surprise, I saw no oil coming out of my turbo oil feed which i ran from a splitter at the oil pressure sensor location.
I disconnected the coils and injector wires for this process.
After cranking it well over 2 minutes - no oil.
When I installed my oil pump, I lubed it with assembly lube but did not pack it with grease... some searching online suggested that this may be a problem.
2)I drained about 2-3qts of oil and forced it under pressure through the oil pressure port.
I cranked the engine and saw the oil coming out of my turbo line and cam rockers.
I also have heard pops and clicks as if oil was squirting from somewhere, but i'm not sure if that sound was also caused by the air coming out along with oil...
I also saw oil floating down from my cam sprockets. Likely from a generously lubed timing chain.
I thought success!! and went on with assembling the rest of the car.
3) 3 Days later after reconnecting everything I decided I'll prime it one more time to make sure there is oil in the turbo line and everything is still fine.
After cranking it for a minute (4-5 15 sec cranks) is saw no oil coming out of my turbo line...
At this point I suspect one of the 2 issues:
I really don't want to pull the engine to check the seal or pull the radiator and remove the balancer to take the pump off
I'm wondering would it be safe to pump some oil under pressure through the oil pressure sensor port again, keep the cover off and watch if oil is flowing and if the pressure light comes on?
If there are any mechanics here, what are your recommendations at this point?
Note:
- There is still air in the pump
- I did not make a good enough seal around the pickup tube from the oil pan and there is a leak there
Note:
- The oil pressure port is my only oil gallery access location. The rest of them are not drilled on my block like they are on gen2 blocks...
- I have a neutral shaft delete kit installed. It consisted of 2 bushings that blocked off one oil port on each side.
- I started with a brand new bare block
